Yes. the fitting that on screws on the tsunami pump is female.
Now I don't want to set the record straight with correct info NPT 3/4 or .75 refers to the inside diameter /ID the outside diameter /OD is what screw together. The threads will MIC. out at 1.0310. (that is center of the run on tapered) on ANY material. That said High fly Dose not use NPT. They don't have to. There system is PROPRIETARY. There fittings MIC. out at 1.0630. They are close in thread count and pitch. That is why you san screw the smaller NPT into them because they are close in size (smaller) They are not the same.That is why you can not screw a High Fly fitting into NPT. High fly are to BIG. LIKE I said "It almost like there metric". That is an assumption.(and a wrong statement) what i should have said is "IT is almost like they are Proprietary". Wait they are.
Here are some pic to help.
metal
PVC
High Fly
Hope this clears things up.
metal
PVC
High Fly
