Best wake shaper for 2009 RZ2
    What’s everyone using? I know it has the step down hull. Thanks. I have the stock ballast also.
    I have one of the first Ronix wedges on my 08 RZ4 and it works great with the larger of the 2 spacers that came with it
    . Regardless of what you use.... you’re going to need more ballast for a good wave. I have the factory 250# hard tanks and a 750# sac plumbed I’m on each side that I fill completely for 2000# total in the rear and a 750# bag up from that I adjust for crew. If I have light crew(2-3 adults beside myself, I fill the front and throw another 550# bag in the middle of the rear seat.
      Thanks - I’m going to add the 550 each side in the rear also. From what I’m hearing that should put out a pretty great wave.
        Ive got three friends that use my wake shaper on RZ2s. They all have awesome waves. They also are all running at least 2500 lbs of ballast in their boats. Third pic is of the shaper on my 22Ve. The RZ2 has a bit smaller spot but my shaper fits perfect on the flat spot. They work great, look good and they float.
        Let me know if you want one. $125+ The trip to you. Typical $10-15 but won’t exceed $19 in the lower 48
