This is info for what I found.
BOAT.. 2000 21V riders 350 merc blue Walter, acme 1433. Lockers have 750 LBS high fly each, bow has 725 LBS Y sac high fly that fills to 600-650, suck gate, Nauticurl. ground down to fit my hull.
ME... 50 years old 5'8" 175 LBS Surfing 8 or 9 years. I can surf regular or goofy not equally but close. Advantage regular.
WATER..Glass 84 degrees. min depth 25 foot
Wave Regular
1 LISTED 1100 LBS no weight front SPEED 10.5-10.9 TAPS 6 LENGTH 16-17 foot HEIGHT 22"-24" more flat not much curl,splashy lip PUSH moderate
2 LISTED WITH A GATE 1100 LBS no weight front SPEED 10.9-11.2 TAPS 4.5 LENGTH 17-18 foot HEIGHT 23"-25" a little steeper a better curl, solid lip PUSH moderate/high
3 EVEN WEIGHT With GATE SIDE see boat above Extra 225 surf side, SPEED 10.7-10.9 TAPS 4.5 LENGTH 20-21 foot, HEIGHT 23"-25" good curl, solid lip PUSH moderate/high
4 EVEN WEIGHT With GATE UNDER Extra 225 surf side SPEED 10.7-10.9 TAPS 4.5 LENGTH 21-22 foot HEIGHT 28"-30" much steeper strong curl, hard lip PUSH high
Wave Goofy
5 LISTED 1100 LBS no weight front SPEED 10.5-10.9 TAPS 6 LENGTH 18-19 foot HEIGHT 24"-26" medium steep not much curl,splashy lip PUSH low/moderate
6 LISTED WITH A GATE 1100 LBS no weight front SPEED 10.9-11.2 TAPS 4.5 LENGTH 17-18 foot HEIGHT 26"-28" a little steeper a better curl, solid lip PUSH moderate
7 EVEN WEIGHT With GATE SIDE see boat above Extra 225 surf side, SPEED 10.7-10.9 TAPS 4.5 LENGTH 21-22 foot, HEIGHT 28"-30" strong curl, hard lip PUSH high
8 EVEN WEIGHT With GATE UNDER Extra 225 surf side SPEED 11.0-11.3 TAPS 4.5 LENGTH 21-22 foot HEIGHT 24"-26" flat low curl, splashy lip PUSH low
I worked on all of these different setups for about 6 hours yesterday. I did try lots of other combos but they didn't produce anything worth mentioning just low push or just crap. It was a lot of fun. Definitely wore this old man out.
With all of this said my setups will be Reg #4 goofy #7 until I try slappers. They need to be built yet I am not sure they will do better, but I am not afraid to try. I am going to try to get all the videos together. I wanted to do them blind so you can pick the wave you think is the best. Some of them were obvious what they were. So I am going to reshoot them. This is a picture of of my under suck gate.
Wave Regular
Wave Goofy
