When I fill my front factory high fly ballast bag I’ve been noticing that’s it’s been losing a lot of water. I filled it up to capacity and put the boat back on my trailer and noticed that the bag was emptying through the through hull fitting under the boat. I’m guessing that is where the pump for that bag is. Other than draining the water out the pump seems to be working fine filling the bag. Is this a seal in the pump that is going bad?
Front factory ballast bag draining under boat?
Tige has had an on a gain off again relationship with check valves in the fill lines. Check the plumbing by the pump and then down in the bilge off the pumps. If you dont see then, then you likely need a couple and this will resolve the passive draining.Mikes Liquid Audio: Knowledge Experience Customer Service you can trust-KICKER WetSounds ACME props FlyHigh Custom Ballast Clarion LiquidLumens LEDs Roswell Wave Deflector And More
