Finally installing it
    Finally got around to installing a system for the rear locker. Pump mounted and hoses are ran. Only have to finalize the switch and add the quick disconnects for the bags. T’d off to use a bag on the rear seat that I ocassionally use depending on how many people are in the boat.
    Someone didn’t want me drilling a new hole in the bottom of the hull so using the existing drain port. But that complicated it just a bit as I still need that drain, so came up with a solid quick connect system with my manual valve for back up still in the event a hose leaks.
    Good job on the setup!
    Oh Yeah!
      I should have done this years ago. Going to be nice not having to open the locker and sitting there filling the bag especially on hot 100 def days
        Cool. You will be stoked with that first fill and also disappointed with yourself for not doing it sooner.
        What sacs are you using?
          Still running my straight line 350s (locker and rear seat), but going to swap the locker bag out to the 370 Fly High will fit in there a little better, that is soon as April 15th is out of the way. Then I keep 250# plates under the rear seat.
            We did get the opportunity to rent a lake house this summer for a few months . Going to make for a fun summer
              Little more progress, wiring done. Moved the radio switch next to my amp switch.
                Have you asked Mike about doing a custom sac? They’re really not much more for something basic like that.
                  I thought about it but wasn’t sure how much weight the fuel tank would hold on top of it.
                    Mike,
                    do you think the fuel tank would support more? (rough measurements are 73Lx21Wx11H)
                      Is it aluminum? Ive got a customer thats been running about 500 in their trunk for about 4 years. is on the false floor thats over the tank.
                        Yep it’s AL with a piece of 3/8” carpeted plywood over it. Sound good I’ll confirm the dimensions this weekend and email them to you. Thanks!
                          Snowed yesterday but went ahead got it all cleaned up so I’ll be ready to go, don’t mind the the messy shop.
                          Filled the seat bag with air to get my hose length cut right
                            Originally posted by Ruger761 View Post
                            Mike,
                            That should get you right around 600lbs just in the trunk. Not bad. Interesting your false floor is 3/8”. Mine was 1/4”. I was running a similar (flyhigh) 350lb locker sac in mine. Never had a problem. I think with the distribution of the weight over the entire “floor”, it should be fine.
                              Used a little length up with the pump but should still get about 500 with the new bag. Can’t wait to try it out!
