Hi, My name is Dustin and i currently work at a boat shop in Elk City, OK. We recently had a customer bring his boat in for a winterization and the customer also wants a bigger wake out of his boat, It is a 2007 22VE with the TAPS2 system on it now and we would like advise on what mods and upgrades we would need to make the customer happy!!! Thanks in advance!!
Biggerwakes Needed
Wake board or surf wave or both? Whats the clients current ballast setup?Mikes Liquid Audio: Knowledge Experience Customer Service you can trust-KICKER WetSounds ACME props FlyHigh Custom Ballast Clarion LiquidLumens LEDs Roswell Wave Deflector And More
Id suggest a custom surf sac or two for the rear locker(s). You could do 1 and manually fill it if you occasionally surf both sides, or 2 if you often surf both sides. They can be plumbed in but not piggybacked to the factory plumbing. Best to manually fill them or plumb them in with their own pump systems.
This would give the boat about 1100 lbs in the locker in addition to the factory 250 lb hard tank.Mikes Liquid Audio: Knowledge Experience Customer Service you can trust-KICKER WetSounds ACME props FlyHigh Custom Ballast Clarion LiquidLumens LEDs Roswell Wave Deflector And More
Originally posted by chpthril View PostId suggest a custom surf sac or two for the rear locker(s). You could do 1 and manually fill it if you occasionally surf both sides, or 2 if you often surf both sides. They can be plumbed in but not piggybacked to the factory plumbing. Best to manually fill them or plumb them in with their own pump systems.
Been a LONG time since I been on here but just wanted to let Dustin know that I doubt anyone has personally done as many installs in a 22VE boat as Mike/Chpthril and his service and support is second to none! He helped me out a ton with my ballast install and I bought all my stuff from him.
Your customer will be very happy with that 22VE wave.Mods: MLA BIG Ballast System (1800+ Custom sacs, 2 500 W705 sacs under bow), Duffy Surf Flap Mod, Trimmed Swim Deck, Top-Mount Starter
If you wanna max it out you should lose the 250 stock tanks. Remove the batteries and battery box(s), build a new rear locker wall, move the batteries behind the rear wall, and get the big custom sized bags Chpthril sells. You’d basically be gutting the stock system except for the switches and wiring. New pumps would be a must if you wanted to get any kind of a decent fill/drain rate on the new big bags.
Pretty sure Chpthril has a bag that’s custom designed to “step” over the top of the battery box if you wanted to keep the stock setup.
Ultimately it depends whether the customer wants an epic wave or just good and if their willing to pay a little extra for it.
Originally posted by 18c racing View PostGet your ballast goods from Mike
And get him one of my custom taps plates and he will be golden
Looking for info of what you just commented on. I live south of you off of Hebgen. I'm tearing through my system this winter and am looking into any modes I can update. I have a fully customized 07 RZ2 with Taps 3, ya. that's right! What taps plate you speak of? I also would like to reorganize my rear lockers as well. I have all stock rear walls, three battery system, hard ballast, etc. Along with added Z shaped bags that rock! They're huge, both sides, big gpm pumps. It's really a Surf boat but do ski occasionally.
Any help would be great. It's winter and time for boat projects!
Happy Holidays to all and thank you for such an informative and insightful forum
JLast edited by Gras'titude; 12-19-2017, 04:20 PM.
J
