Just got my supplies in to plumb in my back bags. But I have just figured out my trailer bunks are really ruining my plans. You guys with 21v's where is talks thru holes in the bottom of your boat?
It's pretty narrow between the bunks. I have been using the plug port as my guide.
Did y'all go behind the bunks back by the transom?
Inside The boat there seems to be all kinds of room but all that open space Is above the trailer bunks. So the thru hole seems to have to be real close to the vdrive. Which I guess isn't a problem but would need to put a 90elbow somewhere on it
I'm trying to install 2 aerator pumps off of a T but I'm starting to think I might need that 90 elbow or a couple of them. Or instead of screwing the T into the shutoff valve have a section off hose connecting the shut off valve and the T which would allow me me to route the hose to where ever I put the pumps?
any suggestions? I was really wanting to use the T for these two pumps. Any pics of how talks is setup with the thru hole?
Thanks
Thanks
