Good afternoon,
I'm curious if anyone has a 2017 Tige R22 and could recommend some ballast and TAPS settings for both Surf, Wakeboard and Cruise
For surfing the manual would indicate a center tap between 4-6 and the surf tap also between 4-6. I'm running 100% ballast in the back and 40% up front but at either of those TAPS I'm just getting a ton of whitewater. The only way I get it to clean up it to run the center TAP at a 1 and the surf tap at a 2, but at that point there isn't much push from the wake.
Wakeboarding I'm running about 40% in the back and 100% up front, with a center tap at a 3. One side is normally good but the other side is normally white water. We were riding with my wife and daughter sitting on the port side with me driving on the starboard. The two of them weigh pretty close to what I weigh so I think we should have been pretty balanced. Does anyone think that one side just naturally needs more than the other? I played with adding more in the rear starboard since that was the white water side but I could really never get it dialed in.
Finally for cruising, once we're above 30mph the boat starts to porpoise violently if I'm at anything more than TAPS 1. The manual seems to indicate that top speed should be reached at TAPS 5-8 but there is no way. Not that I go faster than 30MPH very often but on a calm evening it would be nice to know how to get the speed up a little bit. I've tried putting weight in the bow but that doesn't seem to help at all.
Side note, does anyone know how to engage the AutoTaps and what it does? I thought you just tap the TAPS button on the top right and it's supposed to turn orange but mine doesn't..unless I need to be in a specific setting or something?
Thanks everyone,
Chris
Thanks everyone,
Chris
