So as some of you might already know, I purchased a kit very similar to the factories surf system but from Germaine Marine. After installing I have only been out a few times this past weekend and the results really weren't that promising, quite disappointing actually. But I haven't given up, I believe there are still many things left I can try.
First, we tried a basic setup, full rears (w004 on goofy) and full fronts, ranging from 10.5-11.5. The wave was very very long but lacked quite a bit of push along with all of its height. adjusting the tab up and down, even with the smallest amounts made a big difference. too high there wasn't a wave and the tab too low it just washed right out.
The next day we go out and I completely load down the rear of the boat, full rears as before but another 8-900 spread evenly to compensate for the smaller port ballast, with another 600 in people. With this setup we had many different results, the wave was just a complete wash of white with very little shape. Also, the boat did not want to get up on speed or hold any sort of speed, along with starting to cavitate and getting stuck at 9mph. Are other people having this problem, Am I in need of a new prop? on top of the speed issues, we weren't sure if the tabs were actually engaging properly into the water, the wave wasn't even there. Soon after blowing a fuse.
So basically what I'm looking for is some help on just how to set things up. I have a basic understanding of what the taps 3 guys are running for ballast, it seems like full rears and stock fronts. What I am mainly wanting to know is, how do you guys have your taps 3 set at, what I've found on other threads is all the way down or between 1-3. The only problem is, I don't have TT so the numbers really don't mean much to me, how much deployment really is that? Do little adjustments make big changes?
A friend of mine on my lake just bought a 2012 Z3 and man can that thing surf. Might have got me a little disappointed about mine.
This was the only wave that looked slightly decent, still not what I'm looking for and it's on the wrong side. IMG_3330.jpg
If you guys could give me any advice you've got, that would be great.
