Hi, what would be the best fill percentages for this boat? It has the 2600 lb pro ballast system as well as the convex vx system. What about the trim adjust as well?
Thanks!
Thanks!
I have same setup. I go 100% bow both sides if there are people in the bow less. Can take on waves. 100% surf side. And heavy people surf side if there are any. Taps 4. Surf all day!!!
My previous boat was a 2014 rz2 with vx and pro ballast with enzos and we did 100% in front and surf side in rear and 30/40% off side taps 3/5ish and I would recommend changing the angle of your vx it makes a huge differance also adding a custom taps plate that I build works awesome as well image.jpg
