Looking for a custom Enzo sack for a 2013 z1. I currently have he stock surf ballast and add another 540 and 350 ont eh ports side and I'm tired of filling bags. I have 1 1/8" lines and want a bag that utilizes these lines. Anyone know best place to get them or a phone number. I'm from Canada so the must be able to ship to Canada.
Looking for custom sacks for 2013 z1
Yep, I know a guy!Custom Z1 plug-n-play port and starboard.
Yes, chpthrils MLA bags will work. Just have to tell Mike what you need... he's the best resource on this forum.Last edited by D&P Powell; 05-29-2017, 01:32 AM.
@tigeluv
year, model and ballast option?Mikes Liquid Audio: Knowledge Experience Customer Service you can trust-KICKER WetSounds ACME props FlyHigh Custom Ballast Clarion LiquidLumens LEDs Roswell Wave Deflector And More
Yep, we have custom plug-n-play surf sacs, in the 1000 lb range, depending on side.Mikes Liquid Audio: Knowledge Experience Customer Service you can trust-KICKER WetSounds ACME props FlyHigh Custom Ballast Clarion LiquidLumens LEDs Roswell Wave Deflector And More
Yes, its going to consume the under seat storage when filled. It will mate up to the factory sac plumbing. It takes a little work as we need to convert the hose barb fittings to a two part quick connect setup.
Once we add this amount of weight, we typically find that factory installed props have reached their limits. Hole shot is poor and we start to get a lot of cavitation from the prop. An upgraded prop brings back that performance.Mikes Liquid Audio: Knowledge Experience Customer Service you can trust-KICKER WetSounds ACME props FlyHigh Custom Ballast Clarion LiquidLumens LEDs Roswell Wave Deflector And More
The 2013 Z1 has two issues that you will likely encounter. The first is with the trailer. They didn't re-do the trailer from Boatmate in the 2013 year.... we assume they just used the 2012 Z1 trailer. The result was that there isn't enough clearance between the bottom of the propeller and the prop guard on the trailer. Mine was something like 1/2". So that meant you couldn't add a larger diameter propeller. Tige fixed this by shimming the trailer bunks with chunks of plastic. Even then the clearance isn't great. As a result the 1433 was the largest diameter propeller I was comfortable adding. The 1235 is the same pitch as the 1433 but gives you another 1/2" of diameter.
For reference the stock propeller is a 537 - 13.5", the 1433 is 14" and the 1235 is 14.5".
Post a picture of your propeller on the trailer and we can see if your trailer has the issue. If it isn't a Boatmate, you are likely fine.
The second issue with the Z1 is it likes to lean to one side once you reach cruising speed. We say it "chine locks". It is safe, but annoying.
