Well, it was time to replenish the stock, so we made a little change on the custom. Now offering actuators labeled with positions. Now, just need to mail a set out!
Updated Ballast Switch Actuators
Mikes Liquid Audio: Knowledge Experience Customer Service you can trust-KICKER WetSounds ACME props FlyHigh Custom Ballast Clarion LiquidLumens LEDs Roswell Wave Deflector And MoreTags: None
Nice, my boat has the cover on and I dont feel like crawling in there. Last year if I remember correctly, the switch covers had "ballast" in the middle and "fill" on the top, "empty" on the bottom correct? If so, I may have to buy some of these off you, take my money!
For the transfer pump, do you know if I can get a custom switch cover with "STBD" on the top, and "Port" on the bottom. The arrows always seem to confuse me.
My thoughts with the arrows was to indicate which way the water would flow by which arrow was pushed. I can see where the words "PORT" and "STBD" might work better for some.
PM sentMikes Liquid Audio: Knowledge Experience Customer Service you can trust-KICKER WetSounds ACME props FlyHigh Custom Ballast Clarion LiquidLumens LEDs Roswell Wave Deflector And More
Tigé Junkie
- May 2013
- 920
- Central MN
Mike,
Here is a pic of the switches on our boat, 2 bow and 2 rear. I am assuming these are a just a quick swap out for the switches that we have? If so, I would like to get a set. If you can set them aside, I need to circle back with you on a head unit, remotes and possibly some speakers. Just pulled the boat out of storage this weekend and need to get a few measurements
2007 22Ve Speedset & Switches.jpg."I think I am pretty smart for an idiot"
Yes, its a simple as popping off the current actuator and snapping on the new one. Switch body and electrical stay in place. Just note, I do not have a port and starboard bow switch, so in your case, it would require two bow switched that are the same. other wise, more than happy to supply them.Mikes Liquid Audio: Knowledge Experience Customer Service you can trust-KICKER WetSounds ACME props FlyHigh Custom Ballast Clarion LiquidLumens LEDs Roswell Wave Deflector And More
