I have a 2013 RZ2 with the pro ballast setup. I am looking at swapping out the rear sacs for 930lb fly high bags. I have only had the boat for a half a season, so I am relatively new to the boat. Is this upgrade worth the $1100 for the sacs? Thanks -
Upgrading ballast on 2013 RZ2
Thanks for the response. If I understand my ballast setup correctly, I have 2-250lb hard tanks with 2-350lb bags. So I have 600lb in each corner. By adding the 930lb, that gets me to 1180 on each side. I have thought about the custom tap plates, but want to take baby steps. I am assuming that going from 600 to 1180 will be a big change.
I took a traded in 13 RZ2 out last summer with a VX, weighted mostly even instead of listed with the Mission Delta surf shaper and was super impressed with the wave. Have used the mission and 8.3 surf shapers and think for the $ you can get as much improvement to your wave as trying to slam more weight in, but that's just my preference, and better than having to transfer for reg and goofy riders
Do you have the convex vx? If so you need more weight or fat friends. The convex vx basically adds 2' to the boat. I have the 930 lbs. I fully weight the bow and full rear Surfside. Maybe 25% non surfside. Good wave but better wave is I stick a big guy surfside.
If I do not have the hard tank and 930 full I do not get enough push. But if if there is a lot of people in the boat your set up should work.
Originally posted by JTs-rz2 View PostDo you have the convex vx? If so you need more weight or fat friends. The convex vx basically adds 2' to the boat. I have the 930 lbs. I fully weight the bow and full rear Surfside. Maybe 25% non surfside. Good wave but better wave is I stick a big guy surfside.
the convex vx would be a whale tail looking thing under the swim platform.Mikes Liquid Audio: Knowledge Experience Customer Service you can trust-KICKER WetSounds ACME props FlyHigh Custom Ballast Clarion LiquidLumens LEDs Roswell Wave Deflector And More
I have a 2013 Z1 and I bought the boat new. Despite the dealer telling me it would surf perfect out of the box I had a lot of trouble. Firstly my boat had "defective" brackets on the Vx. But even after that I needed a lot of people to get a wave to surf well. (keep in mind I'm over 250lbs).
In the end the ballast upgrade made the boat much better. The suckgate made it awesome. If you are like me you will keep pushing for the best wave you can. I'd suggest getting the ballast and some sort of suckgate.
Surf board is also a factor. I'm three seasons in and I still don't have a board I love. My suggestion is start with bigger boards then size down as your skills improve.
