Originally posted by gumby 281
View Post
2013 z1 wake surf settings
We have a Z1 with Convex VX.
--We have Chpthril's custom port side sac (1200lbs I think)
We fill:
--front both full (800 lbs)
--port side rear full (1200 lbs)
--three hundred pounds of lead up front. 100lbs as far up in the bow as possible (careful for rollers, you will take on water if you aren't paying attention.
--Two hundred pounds of lead on the port side on the ground. And depending on the crew if it's a small crew a 400lbs sac on the port side seat.
--Starboard side is normally 25% - 50% percent full (600lbs pro sac) fill until listed around 10 degrees in neutral.
Throws a decent wave. Taps @ 1 for skim style at 10.4-10.8. Taps @ 3-4 for surf style at 10.6-10.8.
My Z1 throws the prettiest wave out there. It's not the biggest or longest but for a 21 footer and its price point nothing compares. And in the last 6 weeks I have ridden behind every boat on the surf market. Through competitions and other surf events.
The recall issue is that boatmate made the trailer wrong. If you search the forum there's a bunch of threads about it. Props too close to the trailer because the trailer bunks weren't tall enough. My trailer was fine I have like three+ inches of clearance. Some trailers only had like 1/2" of clearance.
