Fellas, looking for some clarification on some custom bags available on wakemakers.... homefully Mike will chime in here too.
I always run with a light crew. I've done a ton of testing on my Z3 this summer and I've learned that Rayboy's suggestion of a full bow is right on. However, I've also learned the 2000 pounds of ballast my W004's give me is not enough. I've been running spare bags on seats to give me the desired 400-600 lbs extra ballast needed but that's getting old. Ill provide some screen shots of the bags from wakemakers below.
The starboard bag has dimensions of 83L x 23"W x 24"H. The main description has a weight of 1180 and the second screen shot reiterates a weight of 1180
The port bag has dimensions of 83L x 23"W x24"H as well. Main description has 1180 pounds put if you scroll down on the page (second screen shot) list the wight at 1450. I understand the leg could be longer but 300 lbs of longer? Doesn't make sense to me.
If both bags are 1180 they will be perfect for my boat as my 2015 still has the hard tanks in it..... looking for someone who may have real world experience with the bags and real weights.
Thanks.
Thanks.
