how to get good wave behind 08 rz4
    Originally posted by glenn88 View Post
    great shot! sorry for the offtopic, but where are you surfing?
    Apache lake AZ
      Originally posted by trevor View Post
      Joeg, I made some real progress with the wave this weekend. I moved the delta up above the lip wich made it stop washing out so bad, and left the front empty. Filled rear surf side to 100% (stock 250 plus 1100 lb jumbos as much as they can fill) i then let my non surf side empty for 2 minutes (based on my calculations about 250 lbs) taps at 6. Regular side i could run at 11.2, but goofy side did not have enough push at that speed. I dropped to 10.4 goofy side and push was great. I went ropeless as long as I wanted goofy side and i am 6'5" 285 lbs. I figure if i can ride it anyone can.
      Sent from my SM-G935V using Tapatalk
      Try the Taps at 4 and speed at 11.6 on the goofy side. I have found that with the surf assist devices I can run higher spped and lower Taps to get a longer wave with the same push as I got going slower with the Taps set higher. Also, good move putting the Delta higher on the hull, we have seen the best results when we put the devices just below the waterline when underway.
