Ha. Maybe you could pm me?
KillerBren's 2006 22VE Ballast Install
Happy to PM you but I will say they are not the same ones used by a large ballast internet retailer and they are not the home depot sprinkler valves. After testing MANY different ones, I feel these are the best.Mikes Liquid Audio: Knowledge Experience Customer Service you can trust-KICKER WetSounds ACME props FlyHigh Custom Ballast Clarion LiquidLumens LEDs Roswell Wave Deflector And More
Sorry for the late reply. Everything worked great with the pumps, no problems with the fill pumps whatsoever. I did have one issue with the starboard bow drain pump losing prime every once in a while. If you look at the pictures, after the hose leaves the pump it goes down a small amount. After I installed it, I noticed right away but wanted to see if there was any problems. This spring I am going to move that hose up a few inches so it doesn't go down. This should solve the prime problem. Other than that, everything worked flawless! Super impressed, super happy I did the install. My Fiancé surfs on the goofy side and that transfer pump makes a huge difference in the time it takes to go back and forth.
yeah i would tie up that hose to take out that dip. next, we can swap that 90 for straight fitting and get that hose going up right off the pump. let me knowMikes Liquid Audio: Knowledge Experience Customer Service you can trust-KICKER WetSounds ACME props FlyHigh Custom Ballast Clarion LiquidLumens LEDs Roswell Wave Deflector And More
