Hi guys,
I am just getting everything ready and marked to start drilling holes into the bottom of the boat for a ballast install. I need 3 pumps here, and I think I have it set up pretty good, just need your opinion.
The pumps I'm concerned about is the two bottom ones on a "T". They are going to feed my rear port and starboard sacs. The one on the left of the T has a slight upward angle to the pump, then the outlet will be turned upwards slightly, then the hose will go up from there. I don't think I will have any troubles with this pump. The pump on the right however, due to the slope of the hull, has a slight down angle to the black 90, then an upwards angle to the pump. The output will be pointed up slightly and the hose will have an upward slope.
Will I have troubles with that pump on the right side? I'm thinking all of the air bubbles in the T will move towards the left pump and out. I just want to double check and see if I'm missing anything. These pumps will sit about .75" lower after the Thru hull is installed so I can turn them a little bit further up than they are set now, but that T is always going to have a slight downward slope if I set it up like this.
Thanks, I don't want to screw this step up.
