Just installed a automatic ballast system the other day in my 20v. First day I tested it everything worked great. Second time it will not fill. I placed the thru hull fitting, cut off and pump above the transmission under the rear seats have a brass check valve then anti siphon loop. Pump is running when I flip the switch but not sucking water. I have the tsunami 800gph pumps. Im pretty sure I have the pump located below the water line. Not sure what my issue could be
Sent from my XT1080 using Tapatalk
