New Tige owner here. I'm setting up surf ballast on the port side. Has anyone ever done anything like the picture below shows? I figure both sacks will fill till the 325 is full, then the 600 will fill up and vent out. I spoke with wakemakers and the only issue they saw was the 325 might not drain all the way. If this is the case I could always set the boat at 10mph, turn the pump on and all the water should go back to the pump. Sorry for the crappy drawing, I did it in 2 minutes on microsoft paint.
