I have a 900 lbs Sumo Sac and want to swap it out with my factory rear ballast on my 2013 rz2 for surf set up. Can this be done with different fittings? I've contacted wakemakers but they haven't been much help more like a lack of communication.
Balast upgrade
Im presuming your RZR has either the Pro or Surf level ballast with the 350 lb OEM surf sac? The hurdle with that is that the OEM sac has 4 specifically located sac ports. In order to make any other non Tige specific sac to mate with those fittings, you are going to have to cobble together hose sections. Even then, I think you will have some draining issues.Mikes Liquid Audio: Knowledge Experience Customer Service you can trust-KICKER WetSounds ACME props FlyHigh Custom Ballast Clarion LiquidLumens LEDs Roswell Wave Deflector And More
For the RZR/R20 boats, I prefer the Tige designed Fly High W005. It has the 4 specific ports in the proper place for a nearly plug-n-play conversion.Mikes Liquid Audio: Knowledge Experience Customer Service you can trust-KICKER WetSounds ACME props FlyHigh Custom Ballast Clarion LiquidLumens LEDs Roswell Wave Deflector And More
Originally posted by CoreyZ1 View PostWhat about a 14 Z1? I'm looking to upgrade my rear bags I think there 700lbs bags. I've heard there's a 1100 I can swap in.
Sent from my iPhone using TapatalkMikes Liquid Audio: Knowledge Experience Customer Service you can trust-KICKER WetSounds ACME props FlyHigh Custom Ballast Clarion LiquidLumens LEDs Roswell Wave Deflector And More
Originally posted by chpthril View PostFor the RZR/R20 boats, I prefer the Tige designed Fly High W005. It has the 4 specific ports in the proper place for a nearly plug-n-play conversion.2015 Tigé R20
