Johnson Ballast Pump replacement IMPELLER?
    I buggered the impeller frequently pulling the running pump out to reprime it. Two questions:
    1. Has anyone found a place to just get the little impeller?
    2. Does anyone know if a "new" 1250 gph cartridge will fit inside a 1000gph body so I can upgrade flow to the sacs?
    Thanks in advance for the help.
    2010 RZ2 with MLA sac upgrades.
