Having an annoying problem with the front ballast tanks on a RZ2. Have a bunch of riders at different skill levels and the guys that want the most ballast tend to go first up. First fill of the day or first fill after the boat's been out of the water the tanks fills no problem at all. Any time we want to fill the ballast again after operating with half or no ballast it seems to get an airlock of some sort. The pumps are definitely working as you can hear them running and if we remove the clip on the fitting to the tank and give it some encouragement with sucking on the hose , the water flows and you need to get the fitting on the tank pretty quick to avoid filling the boat,
I thought it was the non return valves, but have replaced both and no difference. (valves mounted near the ballast end of pipe, as it comes from the factory)
Have no problem with the rear tanks at all. Told the dealer and they have checked and cannot find an issue. it could be to do with going along for an rider or 2 with full ballast and then emptying for a couple of riders and then trying to refill,the dealer would not have time to test the ballast for this time frame.
Wondering if anyone has experienced similar issues or whether there is a fix or advise
Thanks
Thanks
