Hi guys,
This spring I bought a 2006 22ve. I contacted mike and bought the custom ballast sacs for both port and starboard corners, and a bow sac as well.
1)how much weight is too much weight in the corners? when I fill the custom port bag up full the water level is about 4-6" from the rub rail when not moving and pretty much touching or maybe a tiny bit above the rub rail when moving at surf speeds. Is that too much weight? can I go more (with people ballast)? Is there anything I need to know about having too much weight on one side? I realize when the surfer falls you can't stop abruptly or the wave will swamp you from the back, and no power turns.
2)Ive seen some people comment about using velcro to attach the corner of the sacs to the boat on the corners to hold the sac in place? Is this needed, because I don't have this at all. The bag just sits flat on the bottom of the floor when empty, and when full It pops up, but sometimes its kind of a hassle filling if the bag is twisted sideways. I notice it has some brackets on the bag you could tie a rope to to hold in in place? Is that what they are for?
3) The arms on the bow sac are a little long for under the seats. Ive heard of some guys cutting out the fibreglass partition under the bow seats for more room, is this possible to do without losing structural integrity?
probably more questions to come as I think of them,
Thanks,
Thanks,
