We have a 2007 24ve that we are tweaking to increase weight and we have been trolling this and other sites trying to figure out what to do. Our boat came with factory ballast including two hard tanks along the transom and a bow sac under the front seats. We wanted to maximize the rear lockers and side seats but weren't interested in tearing out the factory ballast (resale, laziness, and an appreciation for how the hard tanks do a pretty good job of utilizing the space back there). Last night I finally got down to it and tore out the rear locker battery and taps enclosures, sat down in the hole and had a gander. I was surprised to see just how much space there was above the hard tanks. In fact, after some measuring, I decided there was enough room on the port side above the tanks to put the batteries. The tank is pretty beefy but I didn't know if it was strong enough to hold the batteries so today I called Tige and one of the tech people figured it would be plenty strong enough. So the plan is to move both batteries to sit on top of the port transom hard tank and move the taps pump on top of the starboard tank. The blower is going to be mounted on one of the stringers glued to the transom. Then I will build out walls for the engine side and transom side of each locker likely using HDPE in 1/2" to 3/4" thickness. This will open up the entire locker for one of Michael's custom sacs while keeping both hard tanks in place.
Here is a photo showing the layout for port side with the engine on the left and the white transom hard tank under two batteries. The battery enclosure and engine wall are removed. We are still working out exactly how we will hold the batteries in place securely but given that the transom is the most stable part of the boat I don't think it will be too hard. In the photo you can see the original battery placement where the trays sit. I will have to organize a bunch of wiring, build two new walls for each locker including a buildout to cover and protect the drain pumps and hoses for the hard tanks. I plan to use HDPE for the walls. At this point we figure we will use velcro between the tanks and battery trays to prevent lateral movement and provide some cushion. Strap the batteries to the trays and also strap the batteries to stringers glued along the transom. Early going yet but I think it will be a good option that maximizes weight and minimizes work. I will post more photos as I go along and if you have any ideas about how to do this better please chime in.
