08 tige 22ve wakesurf
    I was out today testing the 4 fly high sacs I have. I couldn't really get enough push to let go of the rope. My set up was large sac port side, 2 small sacs on the port side seat, and full bow sac. Taps was set at 4.5 n speed was 10.8. Just didn't get that big of a wave. Any help is much appreciated
    Btw, I'm 6,1 195 and also had my buddy 250 lbs sitting on back port side
      Not sure how big the fly high sacs you have are, but they most likely are too small. In my 07 I was running mikesliquidaudio.com or member chpthril on here's custom sac in the rear. Those custom sacs are somewhere around 1300+- lbs per side. The regular fly high 1100 just aren't enough unless you have a big crew on board. You could also throw the Z3 sacs in as they are similar in size to the MLA customs and cost a lot less, they just don't fill completely, but will net you the same weight.
      As far as weight I would fill the rear surf side 100%, rear opposite surf 25% or a little more, and I had the V bow sac that I would fill 100%. Taps around 4 and speed anywhere from 10.4-11. This is the setup I did with the larger MLA sacs.
      With just my wife and I we had plenty of height and push and when we had others on board the wave was extremely nice. Some on her will chime in also as there are plenty of threads about the 22ve ballast installs etc that you might spend some time reading through as there is good info in them.
        Here is a link to my build. Sorry no pics or video of boat after I installed the custom sacs but believe me they are worth the extra coin!
        http://www.tigeowners.com/forum/show...allast+install
