Hello everyone, hope y'all had a Merry Christmas.
I'm looking for some advice on setting the timers for the ballast in the Tige Touch. My questions revolve around the zero point to start the timer. Do you do this when the ballast is completely empty? By completely empty I am referring to dumping the system with the boat on the trailer. Or do you do it once you are on the water and have filled and emptied the system once? I'm nervous about this system as it is running Jabsco pumps instead of the Aerators I am used to. Impeller damage from running them dry while emptying the ballast makes me nervous.
Thanks for the help!
