F*ck! All of sudden during a starboard side fill my boat starts taking on a sh*tload of water....F*ck!!!
It was well above the floor and demanded prompt bailing. We'd just adjusted the prop shaft seal like 20 minutes earlier so right away we figured we'd botched that deal. Nope..that was fine
Turned out to be a 1" tear in my rear sac out on the 'finger'....a nearly new custom 2000 lb. Wakemakers Sac...F*ck!!!! Somehow 1 of the fat rubber grommets I put over the seat mount bolts had come off and ripped the perfect sac
Those friggen bolts need to be trimmed down big time!! Like 'flush' if I really want to be sure this won't happen again.
I called Jason at WM right off and they said get a patch made from PVC 'rubber' and some glue...Glue? What kind of glue. We ended up using this VLP vinyl glue along with a patch we got from the inflatable SUP rental shop.
Scuffed/Cleaned the spot with light sand paper/ rubbing alchohol. Then applied liberal amounts of the VLP (liquid vinyl) glue AND laid down the patch. The patch wasn't that thick. Not even close to the thickness of the sac material. It did have the built in 'fabric' Jason mentioned was ideal. It was free and our only option in our 2 pony town... So we used a sh*tload of the magic glue. Tomorrow I think we'll ad a bit more glue and let cure for another day.
Do you think this mickey mouse fix will work?
If it doesnt I think the next step is to find a used beat up sac and take a chunk off that for the patch material..Maybe Wakemakers has some scraps layin' around..
