Is there a way to reset this or is there another issue?
Rear Ballast still shows 25% Full and is empty...
I took a stop watch while we were on the water and timed the filling and emptying. After I did that I changed the times in the TT. You can only change it by whole minutes. It's not 100% accurate but closer than factory settings. Factory settings for my RZR for the rear is 6 minutes for filling and draining, 2 for the font 400 bag. Front is pretty accurate but the rears is not, especially when draining. Factory settings on my boat will say empty when the rear bags are still emptying the approximate amount of water in the hard tank. It's more like 7 or 8 ish for me. I have the 1000gph pumps I believe.
Originally posted by boardman74 View PostYep the times are almost always off. Welcome to the TT!! You can reset the times right on the ballast screen. Upper right hand corner I believe."Failing to prepare is preparing to fail" John Wooden- Rest in Peace
