What is the ballast hose size on the 2014's? My 13 still had the 800's(pumps) with 3/4 hose. I know late 2013 and all 14's now have 1200's(pumps) with either 1" or 1 1/8". I'm starting to put my shopping list together for ballast system and wasn't sure what size hose and fittings I need.
Ballast hose size
Im coming to the conclusion that its 1.125"Mikes Liquid Audio: Knowledge Experience Customer Service you can trust-KICKER WetSounds ACME props FlyHigh Custom Ballast Clarion LiquidLumens LEDs Roswell Wave Deflector And More
so I have a 2014 z3 and I am in the process of putting aftermarket bags in. My problem is my bottom hoses, my dealer put cuts in them to get the stock bags out. I want to fix this. The easiest way for me is to put a barbed fitting in and extend the hose. What size hose should I order and barb fitting? Do I order 1 1/8th? or 1"? Does anyone make that size barb fitting?
Originally posted by boardman74 View PostThanks guys. Mike I am putting my list together. Going to be pretty similar to my order last year, just with 1.125 hose and fittings instead of the .75. Do you still have the same email?
mikesliquidaudio(AT)bellsouth(DOT)netMikes Liquid Audio: Knowledge Experience Customer Service you can trust-KICKER WetSounds ACME props FlyHigh Custom Ballast Clarion LiquidLumens LEDs Roswell Wave Deflector And More
Originally posted by CarFanatic View Postso I have a 2014 z3 and I am in the process of putting aftermarket bags in. My problem is my bottom hoses, my dealer put cuts in them to get the stock bags out. I want to fix this. The easiest way for me is to put a barbed fitting in and extend the hose. What size hose should I order and barb fitting? Do I order 1 1/8th? or 1"? Does anyone make that size barb fitting?
I know its tot late for you, but for others, all they need to do is carefully cut away the heat shrink and then remove the clamp. break the hose's grip on the barbed fitting and remove the fitting.
Repeat on the other 3 OEM connections
insert the new W746 (supplied with my sacs) into the hose, install new clamp (also supplied).
Install W743 into the 4 threaded ports and plug the new sac in.
If you have my custom sac or the very recent W004/W005 Fly High Tige sac, there are extra threaded ports that need a W731 put into.Mikes Liquid Audio: Knowledge Experience Customer Service you can trust-KICKER WetSounds ACME props FlyHigh Custom Ballast Clarion LiquidLumens LEDs Roswell Wave Deflector And More
Mike
All the uppers are fine. It's the ones below the floor they cut. Those lines are so short I might have to add hose to it once I cut off the area they slit. It's like about am inch. So I wanted to know what size ballast hose to buy. I also need to extend 2 of the vent lines up top to work. I have wake 9 sacs. I will also need a hose barbs for the extension of the bottom lines
Originally posted by CarFanatic View PostMike
All the uppers are fine. It's the ones below the floor they cut. Those lines are so short I might have to add hose to it once I cut off the area they slit. It's like about am inch. So I wanted to know what size ballast hose to buy. I also need to extend 2 of the vent lines up top to work. I have wake 9 sacs. I will also need a hose barbs for the extension of the bottom linesMikes Liquid Audio: Knowledge Experience Customer Service you can trust-KICKER WetSounds ACME props FlyHigh Custom Ballast Clarion LiquidLumens LEDs Roswell Wave Deflector And More
Yes, it will be a little work to gain access, but worth it as opposed to restricting the drain flow due to a barbed splicer. I am not sure what size hose they are using for those sac to tank drains. They were .75" originally, but do not know if they have been upgraded along with other ballast hose as it has been on the new models. If it has been upgraded to 1" 1.125", then I suppose a barbed splicer wont be any slower then what it was with the original roll out of .75" hose.
Last edited by chpthril; 04-13-2014, 04:50 PM.Mikes Liquid Audio: Knowledge Experience Customer Service you can trust-KICKER WetSounds ACME props FlyHigh Custom Ballast Clarion LiquidLumens LEDs Roswell Wave Deflector And More
if in doubt, whats the ID of the hose thats cut? We can nail it down with that.Mikes Liquid Audio: Knowledge Experience Customer Service you can trust-KICKER WetSounds ACME props FlyHigh Custom Ballast Clarion LiquidLumens LEDs Roswell Wave Deflector And More
