This is aimed for the target group of people who put wake boarding before surfing. I am thinking about adding the surf sacs to my pro ballast but I really like the boat the way it is for wakeboarding. I sometimes add a 750lb sac on top of the cooler and adjust the rest through taps. By Adding the surf sacs it changes the ballast weight and I definitely wouldn't fill those sacs all the way up so there would be sloshing going on. All this being said, I am thinking it might be better to just add a sac in front of the rear factory and plumb it in. I am thinking I would get virtually the same weight displacement essentially just dividing the surf sac into two components. Has anyone done this and does 2 sac equate similar to the surf sac?
Surf Sac vs. factory pro system
I wakeboard with custom surf sacs on both sides. All you do is fold the leg of the sacs underneath the main section of the bags. Then fill equal time length and drive wakeboard speed to check for wash. Adjust by adding weight to the side with wash.I do all my own stunt work. hey ya'll watch dis.
I've wakeboarded with 6 guys in the boat and both of my 1100 lb surf sacs full. I had to move 3 guys to the bow to get on plane but the wake was huge. If I did it on a regular basis I would get a better prop but it was doable.
The other guy in the boat who was wakeboarding was just getting comfortable wake to wake and asked to fill the ballast up. After he got booted like superman and crashed hard he asked me to make the wake a little smaller.2009 RZ2, PCM 343, MLA Surf Ballast, Premium Sound.
