Hey
I had a new thing happen tonight, out cruising around all is well decide to do some surfing. Turn on the pump for the port side fill all is going normal (maybe a bit louder than I remember). Start manually filling the front (winter project
front filled. Notice that we are lot leaning over and the bag is sticking out of the locker. I have Johnson pumps above waterline drain and it worked great the last time out. The bag is filled with air and very little water, pull the fill line off the bag and water is only coming out in spirts not a steady stream.
Thinking bad impeller, get home. Tear it apart and it looks great. This is only the second time out on this new install. Tear the other side apart to compare and they look exactly the same. Both are Black impellers.
Any ideas? on what else to check.
Thanks
Thanks
