Originally posted by chpthril
View Post
need help to cross vent and drain my 2013 z1
Originally posted by snroth View PostWhat happens when you empty the tanks though?Originally posted by snroth View PostNo ****, what displaces the water when you have a check valve in the vent line like you said to install. Pumps aren't going to pump very good when drawing a vacuum.Mikes Liquid Audio: Knowledge Experience Customer Service you can trust-KICKER WetSounds ACME props FlyHigh Custom Ballast Clarion LiquidLumens LEDs Roswell Wave Deflector And More
I ended up ordering the hose off of wake makers and 4 check valves for the fill lines. I cross vented and drained the rear sacks and installed check valves in the fill lines. I ended up putting in a barb fitting on the drain lines and just went straight off of the y fitting for the vent. It was no problem once I removed the rear cover panels. Two issues that I had with the installation was there there is a small circuit breaker that is installed above the port side through ports (for anyone that is doing this to their boat MOVE THE CIRCUIT BREAKER) obviously I had issues when I got on the water. Second issue was the the port side trim panel, I Had to take a skill saw and trim the corner off to allow the panel to sit in its natural position. To insure that the sharp plastic edge didn't cut or score any of the hoses I filed it down with a file and it worked out great. Im not sure how you guys mounted the hoses across the back of the boat but I took off the black plastic trim panel over the motor and drilled a series of holes so I could put the tie wraps through and hide the hose behind the panel.
Originally posted by kasey200 View Postyou may want to install check valves in the fill lines as well. I was loosing water through them in my RZ2
Also, be sure to install the check valve between the pump and the Y that splits the fill lines to the sac and the hard tank. I didn't know about the split and installed mine up near where the fill line enters the sac and still had passive draining through the fill line. I believe that's because it was draining out of the hard tank fill line. I just recently had the check valve moved to between the pump and the Y, and I plan to test it in the next couple of weeks. Hoping that does the trick.
I really like using qwik-lok fittings on everything. You might try quick locks from here, and they come in 1-1/8in sizes. Makes maintenance and troubleshooting a breeze when you have qwik-loks on everything.
https://www.flow-rite.com/products/m.../1-18-fittings2013 Z3 - Electric blue and black
What year is your Z1? The 1st gen Z1 used .75" hose and the 2nd gen (current) uses 1" i believe.Mikes Liquid Audio: Knowledge Experience Customer Service you can trust-KICKER WetSounds ACME props FlyHigh Custom Ballast Clarion LiquidLumens LEDs Roswell Wave Deflector And More
Tigé Junkie
- May 2013
- 920
- Central MN
If I recall, there was a mid year change. The 2nd gen started with 1" and sometime prior to mid-May 2013 builds they increased to a higher volume pump and increased the hose to 1-1/8". When we took delivery on ours, beginning of June, our salesperson stated that he was suprised that our boat had recieved the upgrade as he thought it was due out later (at least that is what he said)."I think I am pretty smart for an idiot"
I think cross-venting will be the next mod to my boat. I'm still running stock pro ballast, but the fill times seem to be far too short. Further, the passive draining is quite noticeable at list.
My Z1 is a July 2013 delivery, so it sounds like I have the upgraded pumps and larger diameter fill lines.
I'm not sure if this is apples to apples, but my fill times are about 2:30 for the front bags and 5:30 for the rear bags. Maybe these are high flow pumps, but it sure seems like these bags are not getting to capacity. Can anyone comment on their fill times?
