I finished the bulk of my ballast install and have been wanting to put it up here. I read almost every ballast install thread on here and it was a ton of help. IMO, Tigeowners.com has the most comprehensive ballast install threads out there. I read a few on other websites but we are loaded with great content here. My install was not nearly as complex as others but maybe there will be some useful info for others.
If I had tried to build / buy a custom system from parts at the hardware store or marine store etc. It would have been a nightmare by not having my safety net, Mike (Chpthril) a phone call away.
The best thing I did was call Mike after reading about the glowing recommendations on here. I bought pretty much everything from Mike. He walked me through everything from design to finish. I would not hesitate recommending Mike's Liquid Audio to anyone.
When I first bought the boat, I was planning on filling manually with Tsunami's the first season. Well, two trips and the wife nixes that idea.
Sacs (All Fly high Fat sacs):
2 Rear Lockers - Jumbo W719 DIMENSIONS: 50 x 24 x 24 WEIGHT: 1100 lbs. / 500 kg. Sac is longer than compartment by 10". It is shorter than compartment. The rear lockers are REALLY deep.
2 Under Rear seat sacs - W705 DIMENSIONS: 60 x 26 x 10 WEIGHT: 650 lbs. / 295 kg. Fits really well. Thanks Duffy for posting your custom sac dimensions, it helped find a good underseat sac.
2 under bow seats - W701 - DIMENSIONS: 42 x 16 x 16 WEIGHT: 400 lbs. / 181 kg. each These don't fit the best but I already owned these and could re-use them. Seem to work ok. A longer sac might work a little better or the integrated bow sac.
Mike originally recommended Enzo's for the rear but at the time. I decided to go with separate rear locker sacs and underseat sacs because I was planning on manually filling the sacs and I thought I might want to move the opposite side sacs around if I had a small crew to get more weight. I thought it would give me more flexibility.
If I were to do it again. I would go with the Enzo sacks or custom sacs (Duffy sized
). I ended up tying the two rear sacs to the same switch so no benefit to me for the rear sacs.
Pumps -
6 sacs so 12 pumps
8 Atwood T800s
4 Atwood T1200s
I am going to break this post into multiple posts and hopefully there will be something useful out for someone else.
Pumps -
6 sacs so 12 pumps
8 Atwood T800s
4 Atwood T1200s
