I had my port locker 540 lb launch pad bag split a seam this last weekend. The split is ~18-20" long and is directly on the seam. Is there a glue that can hold up to the pressures of a full 540 lb bag if I used it to glue a strip of the same material to repair it maybe? or try to seam weld the material... what exactly is the material and what is the repair process?
I would love to buy an 1100 lb sack for the port locker for surfing, but the expense of a new rear trailer axle, trailer tire, steering cable, impeller, oil, gas for the trip etc... leaves repair to be the best option for our wallet.
