2006 Tige 24ve Ballast for Wakeboarding?
    I'm having some problems with white wash on one side of the wake, we constantly move people around and weight and as soon as we get it leveled out it'll go back to white wash....
    currently i have a jumbo sac in each v-drive compartment which hold an estimated 900 lbs each, to try and help it out i've put a 400 lb v-drive sac in the bow on the floor.
    Do Tiges have a problem when weighted with white wash? and what weight set ups do other have that help?
    By the way i'm impresseed with the size of the wake, im used to riding Nautiques and Supras which are ramps and with taps at 7 and 2200 lbs of water the wake is comparable, not as abrupt but impressive in size. I also noticed the wake is not as wide as I would expect which is great!
    You need more bow weight. I have the same boat and we have the same sacs in each rear locker, then we have 2 sacs under the front seats that probably hold about 250 pounds each. You may also have to move taps to around 3 or 4 to push the bow down a bit. Tige's do seem to be picky with side to side weight so just move people around until your wake is clean on both sides. We ride at about 24 to 24.5 mph which makes the wake really clean. Good luck.
      You need to try and get a 60/40 split because you do not have enough weight in the bow. Tiges 24ve likes that split so u would need 2700lbs up front to compensate for the 1800 in the back. Or with your 2200lbs now, get 1320 of it in the bow and put 880 of it in the back.
