Hey y'all,
Thinking of adding this to my factory ballast system.
http://www.wakemakers.com/tige-piggy...upgrade-1.html
Any thoughts on it? Sounds like it will fill okay, but might drain a bit slower. From my understanding, the OEM pumps will fill the bag first, then when its roughly 1/3 full, the gravity will push the water into the hard tank and eventually create enough back pressure and continue filling the newly added #750 bag. The draining pump is attached to the hard tank, so water will have to drain into the hard tank and I assume this will be slower. I considered adding a T at the thru-hull port and just adding another pump but I believe I was told that the 3/4" opening in the hull would limit me and I wouldn't see a big decrease in fill time. Obviously if I had a separate draining pump, that would speed up that end of things. Just seems like it would be an easy/cheap/quick upgrade at the expense of slow drain times.
Thoughts? Anyone know how much ballast comes in the 2010 Z1 factory ballast?
