Just bought a 2013 RZR and it just came with the basic 900 lb ballast. I want to add more mostly for surfing. I want it plumbed in and don't want to pay the $1000 for just the rear 350's from the dealer. I am not a pro rider and the 900 stock is more than enough for me when wake boarding for now anyway.
Can someone describe the plumbing to me who has the surf ballast from Tige?
Here is what I want to do. Add somewhere between 350's and 500's to the rear. My thought it to put a Y at the 2 rear fill pumps with a valve so I can shut off the bags. T into the vent line. Then add a separate drain pump and add another thru hull along with the 2 that are at the back below the rub rail(one on each side) for draining the sacs
Is there a way to avoid another hole in the boat? How does the factory surf bag drain? How can you tell when the tank is full since they now share a vent/overflow line? The bag you can obviously look at. I remember someone telling me something about pumping the bag into the tank to be drained?? Seems silly to pump the water twice.
