'12 22ve ballast upgrade
    I just added a 1350# fly high sac to my Z3 a couple of weeks ago. The install was very simple, and could've been completed within an hour if the 2 drain hoses would've lined up. I had to add about 2" of 3/4" hose to one of the drains, and 3" to the other. Instead of adding a pump controlled by the tige touch, I opted to put a quick-connect to the top of the sac so I could use my tsunami pump to aid the factory pump. Between the 2, it took about the same amount of time to fill as the stock 350# sac. I would like to add that the 1350# sac is only worth-while if it's just you & 1 or 2 other people on the boat. Otherwise, it's simply too much weight to get a good wake. If you have any questions, feel free to ask.
