Today I installed my side-to-side transfer pumps. I'm using two Rule 405FC's running between the aft sacs to 1) double the speed of fill and drain, and 2) double the speed of switching from normal to goofy side. Each pump takes its intake from the bottom of one sac and fills into a top port on the opposite sac.
Everything worked great right from the start. Filling and draining are much faster, as is switching sides. However, I noticed that I was losing water out of the port (normal) side sac. Maybe I have a leak, I thought. After we switched sides, I found I was losing water out of the starboard sac too! Odds of matching leaks on both sides: Almost zero.
A bit of investigation revealed what is happening: When I drain one side, it is actually suctioning water through the fill hose from the other sac. Thus it is not only draining the intended sac, but the sac on the other side too - through the transfer hose that intentionally moves water that direction when the associated transfer pump is turned on.
I can't fix this with a check valve because the suctioned water is moving in the same direction as the desired water when the pump is on. At the moment the only idea I have is to make sure there is an air pocket in the top of each sac so when the transfer pump isn't running there is a vacuum break to prevent the flow from starting.
Anyone else encounter this? Any better solutions?
