Skippa whoever is riding in those pics would have done much better if they hadn't let off the gas right at the wake.
22ve advanced level wakeboard wake. how much ballast?
Originally posted by cgl528 View PostI am buying a 2007 22ve this week. It does not have any ballast options on it but is a killer deal. I am wondering how much ballast I am going to need in order to get a exceptional wakeboard wake? What sacks should go where? I don't really care about surfing right now.... still have knees for the time being.
I am also wondering can you put any of the sacks under the floor? I'm guess I will have plenty of room in the back for above floor. But can I fit anything under the floor in the front?
Any suggestions?FairTax.org
Originally posted by Bruizza View PostSkippa whoever is riding in those pics would have done much better if they hadn't let off the gas right at the wake.
Thanks for the pictures!
I am thinking that my best bet is fly high sacks with two 750s in the rear, one in each side, and a integrated bowel sack in the front.
Anyone have any idea how much weight you can get filled into a bowel sack if I plumed it up front under the seats? How full does that amount of space allow the sack to get?
Originally posted by Alta Dawg View PostPlease explain the 45/55 split...I'm new to the site. Thanks!
You will have to test to see how your boat works based on people in your boat, supplies, and lake conditions as well. Some will say you need more up front others say the back. Just be careful when adding weight up front not to dunk the nose of your RZ2. Where in Utah do you ride?
ballast
I am also about to add ballast to my 2007 RZ2. I am going with two 1300lb sacs in the rear and a 400lb sac in the bow. they will have tsunami pumps. I got my quote for it just under 4 grand installed. I have had several friends get it done at the Tige dealer in lake of the ozarks and they have done a wonderful job. They will be the ones to install mine.
I don't know if the 2006 has same hull as 2007 22ve but I tried to get some pics that will put the wake into perspective. I'm 6'1" if you need a height reference.
70 ft rope at 23.5 mph
taps at 6
750 fly high in each rear locker
400 vdrive sack on ground in front of rear seats
400 vdrive sack in walkway
1000 fly high triangle bow sack in front 3/4 filled
4 people in back
