Recently installed an Enzo Sac in the Rear Port side Locker. It was a simple installation replacing the existing 350# bag. After reading some threads and observing the previous sac not remaining full during surfing I installed a simple Ball valve prior to the thru hull "vent" opening.
After filling the entire bag and observing the water coming out of the vent and a trickle out of the drain as well I shut off the pump and closed the ball valve hopefully locking the bag permanently in its full state.
After only 20 or 30 min I noticed somehow the bag had lost 1/4 of its contents.
the Diagram below is my understanding of the ballast system, it's not complete since I couldn't really get a good look at where each fitting connects to either the hard tank, pumps, or vents. In my RZ2 the vent line seems to be T'd off to another line which seems to maybe run across to the other "starboard" side vent?
Hoping somebody can finish my diagram or shed some more light on how I can lock in the full 1200# of water for surfing.
When the bag is completely full I see water coming out of the Vent hole and a trickle coming out of the drain hole. This makes sense since I suppose the weight of the water plus full bag plus ballast pump continually pumping in more water will actually push past the drain pump and up and over out of the drain. But...will normal ops "surfing" keep pushing water past the drain pump? If so, what good would a one way check valve from "wake makers" do on the drain line to stop this?
