I noticed this past weekend that the factory 'Surf L' and 'Surf R' profiles show 100% ballast in the bow but it shows it per side. For example, if you set it to Surf L, the port side rear ballast fills to 100% and it shows that the port side bow ballast to be at 100%.
This seemed strange to me as it is a single U shaped sac. Is it actually just filling the one side to capacity? I kinda think it is since once the profile was set and the port side bow sac showed to be at 100%, I disabled the speed set, went to the ballast screen and hit fill for the bow (which does not give you the option to fill one side or the other). The ballast pump ran for several minutes before it started emptying out of the vent.
At any rate, I have 520lbs of Pop Bags coming in on Monday which will definitely help with the lack of bow weight at times. Each bag is 40lbs and I'll have 13 of them. I plan on adding them in the following locations:
Port battery locker - 2 bags = 80lbs
Starboard battery locker - 5 bags = 200lbs (to make up for the extra ~120lbs of the port side stereo batteries)
Bow - 6 bags = 240lbs
Any suggestions as to where I should place the 6 bags in the bow? Is it better to just space them along the outside of the hull as far up as I can reach, under the factory ballast bag?
Under the removable bow cushion there is a roughly 3" hole (is there supposed to be some sort of cover or plug over this?).
I figured I could open this up a bit and it might allow me to place the 6 bags all the way up in the pickle fork area. Would this be a bad idea? It makes sense to me that the more weight I can get all the way forward in the bow, the lower the bow will be, which should make it easier to get out of the hole with a lot of weight in the rear.
I'm not sure yet how well these bags can be manipulated but there is some unused space behind the bow speakers that would probably work well also.
Thoughts?
Thoughts?
