Sac Protection
    Sac Protection
    I am just getting to the end of changing out to MLA's plug and play ballast sacs to my stock 2008 Z1 Ballast package. Nothing near what some of you all have done. I'm just pulling the stock above floor hard tanks and swapping the Enzo style sacs. and swapping the discharge of the Vent and drain hoses to the opposite sides
    With the Enzo style sacs extending into the storage areas I had to do something to protect them from the seat hinge screws, I came up with using wire nuts and I'm thinking they are going to work pretty good
    What roll do the flip flops play?
    BTW, great idea!
      Great idea! Looks good!
        I started work on your marketing campaign...
          Where did you get a bag that large That must have cost over $200.00
            These are marine grade plastic! They won't rust like ordinary plastic does!
              Great idea.
              I used small corks and screwed them up onto the exposed threads. Not one has come loose in three seasons.
                i use a cup to protect my sac
                  Flip Flops are for your feet Skippa.You can use them on gravel or hot asphalt to protect your feet from hazards.
