Chpthril- knowing that I'm going with 2-400lbs sacs in the front is it best to factory order with 2-200s vs 1 400lbs sac.
2012 Tige rzr
Originally posted by Johnnymac View PostChpthril- knowing that I'm going with 2-400lbs sacs in the front is it best to factory order with 2-200s vs 1 400lbs sac.Mikes Liquid Audio: Knowledge Experience Customer Service you can trust-KICKER WetSounds ACME props FlyHigh Custom Ballast Clarion LiquidLumens LEDs Roswell Wave Deflector And More
Originally posted by mls6722 View PostDoes anyone know how much two 400# sacs would fill? On my 22Ve, my single 400 does not fill to capacity. Is the Rzr bow space larger?
The RZR definitely needs more weight up front!
Yea the rZr does need more up front. Just cram a person or two in the bow or Add a sac if necessary is what I do.
No you don't need to re prop chp is right on the prop I believe and thing has absolute balls, goes 47 and pulls hard outta the hole with over 3k of weight.
I just run a 500 # sac and people extra under the benches for surfing and the wake is quite nice, could it be bigger? Yea. Would it get sketchy? Probably. It sits about 3 inches from the rail as is with that weight. Then I just toss the bag up front if I think it's necessary.
So if this is the case, one could get a little adventurous and cut out the divider and allow the sacs to fully extend.Mikes Liquid Audio: Knowledge Experience Customer Service you can trust-KICKER WetSounds ACME props FlyHigh Custom Ballast Clarion LiquidLumens LEDs Roswell Wave Deflector And More
Originally posted by Johnnymac View PostAwesome,can you pm me with pricing for the 2- 400lbs sacs and the two rear surf sacs. From what I understand, for the rear bags, you can just fold the bag under the sac for wakeboarding and extend the bag under the seats for surfing and just set timers for each setting.
Also as you mentioned the two 4oolbs sacs are avaliable for the front and someone also mentioned that you can factory order with two 200 lbs sacs vs 1 400. I would think that the 2- 200lbs sacs would be the way to go to easily plug and play for the 2- 400 lbs up front? do the 400lbs bags fill full?
Thanks to all for feedback and the welcome to the Tige Crew. I am doing a one off RZR with All black, mushroom pannel with graphite pannel trim and brow. Interior will be mushroom where the white is 80% of interior, Graphite secondary colour and minimal white.
Should be a beauty...I am pumped to factory order a boat that will fit in the garage. that being said, I am getting a tower soc cover made to protect from bugs when trailering. Also going to get the dealer to install a roswell c4 lightbar! Does anyone have comments on that lightbar on the Alpha tower or have a better suggestion?
I will post some pics.Mikes Liquid Audio: Knowledge Experience Customer Service you can trust-KICKER WetSounds ACME props FlyHigh Custom Ballast Clarion LiquidLumens LEDs Roswell Wave Deflector And More
Originally posted by Johnnymac View PostCHPthril- Still waiting on that pm for pricing on the custom rear sacs.
Sorry for the delay
MikeMikes Liquid Audio: Knowledge Experience Customer Service you can trust-KICKER WetSounds ACME props FlyHigh Custom Ballast Clarion LiquidLumens LEDs Roswell Wave Deflector And More
My 400 lb bow bag fills 100% and I see verry little extra room under the bow. If you go with 2 400 lb bow bags, the bag legs must extend into the storage area in front of the driver and passenger seat compartment to add the additional weight. Having said this, you would lose some storage space. If you do get these 2 400lb bags, please let us know how the boat performs with the weight to 1 side.Nick
Dayton, Ohio
Yes the RZR arrived in Muskoka Ontario at Port Sandfield Marina. I take delivery in two weeks when the gen 2 clamping board racks arrive. In the mean Time they are installing 6 led Roswell tower lights for surfing at night and making a custom tower sock for trailering. Boat colours turned out amazing... I think it was a first for the interior choices. Will post pics soon and put in 2 400# v drive bags in the front and update on how much the fill/extend.
