Originally posted by Stingreye
View Post
2007 22Ve Ballast Install
Originally posted by SBM1234 View PostThat looks great!!!! One of these days we are going to have to do the same, thank you for sharing your experience. Were your hands shaking when you drilled the first hole?
It is much better then manually filling the sacs.
Originally posted by chpthril View PostLOTS of wire tiesJBorts was about the same way. I rerouted, disconnected, reconnected and zipped tied like crazy to get the battery cables cleaned up.
I see where you helped out skippa on his ballast install and I had a quick question with regards to the electrical connections under the dash. do you recommend getting a separate distribution fuse block or tying into the factory fuse panel like skippa did? I'm adding a total of (4) Johnson and (3) Tsunami pumps (hybrid system) and I don't want to overload the factory fuse/breaker box.
Originally posted by XXV at last View PostHey chpthril,
I see where you helped out skippa on his ballast install and I had a quick question with regards to the electrical connections under the dash. do you recommend getting a separate distribution fuse block or tying into the factory fuse panel like skippa did? I'm adding a total of (4) Johnson and (3) Tsunami pumps (hybrid system) and I don't want to overload the factory fuse/breaker box.Mikes Liquid Audio: Knowledge Experience Customer Service you can trust-KICKER WetSounds ACME props FlyHigh Custom Ballast Clarion LiquidLumens LEDs Roswell Wave Deflector And More
