There are two buss lines that run the length of the box. Off of the those the breakers are hung with a screw, that is how the line side of the breaker is connected. The load line side of the breaker is on the outside of the buss lines. So the breaker is held in place by both the screw that connects to the buss and the hole and plastic nut on the outside of the breaker box. The breaker that I got from Mike has both terminal straight. I positioned it in between both buss lines. I didn't want to take everything apart so I put it in there and from the looks I drilled. It ended up that I was a smidge off so I had to enlargen the hole. As always working in confined areas is not easy, I am not a small dude and I had to be careful with the breakers that were already in there.
2007 22Ve Ballast Install
Getting really close to done. All the wire is ran and tied. Hoses all done. Battery wires cleaned up.
All that is left are the switches. I wanted to try and match the factory switches. You can not get them in black lettering any more from Tige to match the other switches. They have gone to a white lettering that is not on the led. I was able to find the switches just not labeled, for a 1/3 of the cost of the ones from Tige. I have a couple of ideas on how to label them. They should be here tomorrow and I can finish up.
