locker view.JPGIf your not tired of ballast install threads I have one more for you. It is definately not as detailed and complicated as many others in this section but thought I would post since it is a little different.
I have a 2010 Z1 with the factory ballast (400 single bag up front + 2X250 rear hard tanks). I have also been using a 750 fat sac for surfing that I manually fill. Decided to add a bigger (ever heard of going smaller
and plumb in. However, I have a wrap on my boat and the vent/drain thru hulls are wrapped.thru hull wrap.JPG
To eliminate the need for thru hulls: this is what I came up with...
1. Use the fill pump for the port side leg of the bow sac and capping the port on the sac. Obviously this not only eliminated the need to put in a new pump but the need for installing a new switch as well. Understanding that this will increase my fill time for this sac. However, the surf sac is still much larger requiring a longer fill time anyway.
2. Use existing port bow drain for my drain and fill for the surf sac. Put a Y in the vent/drain lines coming off the new surf sac about three feet outside the rear locker. Ran the drain/vent line high up the port side gunnel to common port bow thru hull.
Ready to test....
Let me know if I missed anything!!!
Goodies for the job were from Chpthrl. Mike was great to work with. Not only was everything as describe, on time, complete, but Mike took several calls from me when I had dumb questions.
Here is a pic of the sac (which I hope to get about 1000-1100lbs out of...
Ready to test....
