How big of sacs are you going to be able to fit?
NICKYPOO's Ballast Thread
Originally posted by duffymahoney View PostHow big of sacs are you going to be able to fit?
Originally posted by jason@wakemakers.com View PostLooking good! Are you just going to use an epoxy resin to treat that ply, or are you planning on glassing over it as well?You'll get your chance, smart guy.
I had a buddy that had his trailer sprayed with liner material from one of the major companies (Line-X, Speedliner, etc.) and they left out the texture beads, so it was just the rubber binder material. Gave it a pretty cool flat black finish that had some grip, but wasn't nearly as rough as a typically bed liner.WakeMAKERS.com | WakePROPS.com
There are some materials I use for waterproofing walking decks and roofing that would work. They are all water based and use either fiberglass or polyester mat for reinforcement. Good stuff, but proabbly not easy to locate?
http://www.alldeck.com/
http://www.lifedeck.com/waterproof.html
http://www.garagecoatings.com/Waterproof-Deck-Coating
http://www.hydrostop.com/Mike Allen, Tigé owner since 1997
Thanks TA. I have a good friend that owns a coating business, http://durastonenv.com/index.html, and he brought me some samples of some of that stuff so, not tough to find after all.I might still go that way.
I spent a lot of time on one stupid panel this weekend. I was completely frustrated Sat night. I spent all day trying to fit these three pieces together and finally had to walk away with them not at an acceptable state of completion. It was the first time this project made me sad. Boohoo. Went out Sunday morning, nailed em up, made a few adjustments and BAM!, it slid right in. I was much closer than I had thought. Anyways, this is the blower chase. I wanted it to be sealed off so fitting it to the inside of the hull was a B. It's going to need a little more love to get it perfect but, I'm happy with it. It's just sitting there unattached in the pics. It fits much tighter than it looks. The other side is nowhere near as critical as all it will house is the overflow for the fuel tank.Last edited by NICKYPOO; 02-13-2012, 05:40 PM.You'll get your chance, smart guy.
Good question. I wanted the entire area to be waterproof. Carpeted wood panels are not waterproof. All the carpeted wood panels I pulled out had some sort of rot and I live in the high desert where we see many days of single digit humidity. The only way to eliminate rot is to coat them in one of the modern day coatings. I might actually carpet the cabin side of the seat backs just because they will be direct contact with the rear seat but, beyond that, its gonna be carpet free. No vacuming, no setting up the fans to help dry it out, nothing. Just hose it out and park it.You'll get your chance, smart guy.
Tigé Jedi
- Jul 2010
- 4302
- TN USA
Originally posted by NICKYPOO View PostAll the carpeted wood panels I pulled out had some sort of rot and I live in the high desert where we see many days of single digit humidity.
Tigé Jedi
- Jul 2010
- 4302
- TN USA
Originally posted by NICKYPOO View PostNo, my point is that even with basically no humidity, wood panels with only carpet for protection are still going to rot.
For exactly the reason you mention, I try really hard to not use wood in marine applications. That's why I used Starboard when I did my ballast install - it's absolutely rotproof, workable like wood, dries fast when it gets wet, etc. It costs a bit but I will never ever have to think about it rotting or worry about it getting wet.
