These sections of floor have to be cut out. There is no unscrewing them and pulling them up. That section is glassed in and there is tons of glass to cut through which leads to much more "cleaning up" of that area. I mean, they are glassed in to the top of the stringers even.
Once you removed your foam, what did you use for a bulkhead in the front of that section?
Yes, I'm considering this more and more. Maybe if I put enough weight back there, I will need to put some ballast up front. "Sorry Honey. I guess I did too good a job on the rear. Now we NEED to do the front." I really want to cut the "cooler" out from under the observer's seat and put a sac in place of it. I figure its worth 200#, hidden. It completely unused now other than being misc. rope storage. It would be nice to negate any possible driver weight when surfing port.
